Enduro Pre-Cat Urethane Sanding Sealer
When only the best will do! Enduro Water Based Pre-Cat Sanding Sealer is a clear undercoat that forms an easily sandable foundation for any GF Enduro water based top coats. The high solids content builds a fast film. The stearates make the sanding process smooth and easy, drying tack free in 10-20 minutes. Recommended Accuspray HVLP atomizing sets: .043 -.051 tip and nozzle, No. 9 -10 air cap.
Note: always use Pre-Cat Sanding Sealer under Pre-Cat Urethane.
Application Brochures
Material Safety Data Sheets
Technical Data Sheets
