Wood Turner's Finish is a water-oil urethane hybrid for use on wood turnings, bowls and other lathe-turned projects, now made with more than 50% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint.
There are four benefits to using sanding sealer as the first seal coat prior to topcoat
Wood Turner's Finish does not need wet sanding. If feel the need for more sheen, dry polish with Merka Abralon 1500-4000 grit or Micro Mesh 4000-8000.
General Finishes Professional Enduro White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes.
Walter Ambrose sure is talented.
ENDURO PRO SERIES SELF CROSS-LINKING CLEAR & WHITE POLY by General Finishes
Get professional performance for a competitive price. This new pair of ENDURO topcoats are tintable, fast-hide coatings for professional and industrial use. The high solids content provides strong build and 2-coat hide when primed with Enduro White Undercoat or General Finishes Stain Blocker.
General Finishes water-based Enduro Pre-Cat Lacquer clear-drying wood finish uses new technology in the polymer manufacturing process. This unique formula produces a smaller and smoother particle, translating into a big increase in film clarity.
