General Finishes RTM (Ready To Match) Stain System for professional finishers, industrial users, and OEM manufacturing facilities makes color-matching the easiest process on the market.
General Finishes water-based Enduro Pre-Cat Lacquer clear-drying wood finish uses new technology in the polymer manufacturing process. This unique formula produces a smaller and smoother particle, translating into a big increase in film clarity.
Enduro White Poly is a professional high-solids, pigmented water-based wood finish engineered for cabinets and millwork.
GF's Exterior 450 Stains are low VOC premium quality, exterior pigmented water-based wood stains designed for outdoor projects with vertical surfaces such as garage doors, entrance doors and furniture. Can be applied to wood, MDF, and fiberglass.
Water-based Conversion Varnish is a clear drying, two-component, post-catalyzed urethane topcoat for professional, industrial and OEM use when high durability is needed.
